Pages: [1] 2 3 4   Go Down
Author Topic: AES50 splitting  (Read 3089 times)
Andrew Broughton
    • Check Check One Two
AES50 splitting
« on: September 10, 2017, 03:41:50 pm »
I'm familiar with how Dante sends a signal to multiple destinations by sending multiple copies, but how does it work with AES50 like with Midas or Behringer products?
Say I had an AES50 I/O preamp box. How would I send that signal to 4 mixers for example?
-Andy
Philip Roberts
  • Church and H.O.W. Forums
  • South West MI
Re: AES50 splitting
« Reply #1 on: September 10, 2017, 03:59:49 pm »
I believe that AES50 is a point to point protocol that just happens to use Category cable so these isn't a way to do this simply.
Philip
Andrew Broughton
Re: AES50 splitting
« Reply #2 on: September 10, 2017, 05:04:02 pm »
Philip
Really? That's surprising. If that's true then you'd think there must be splitter devices.
Sent from my iPhone using Tapatalk Pro
-Andy
Caleb Dueck
    • Excel AV Group
Re: AES50 splitting
« Reply #3 on: September 10, 2017, 05:35:09 pm »
DL431.  Splits preamps to (2) consoles.  At the console, further splits are possible via Dante or other networked protocols.
The link between console(s) and preamps and the associated control implementation is arguably different than the needs of distributing multiple feeds to various pieces in a system.  Most manufacturers have chosen some flavor of point to point from pres to surface, then Dante or similar for the "audio system network" protocol.
Will Dante or some other protocol take over as the best way to get any audio signal to any device?  Possibly at some point, but it looks to be a ways out.
Excel AV Group
David Sturzenbecher
    • Sturz Audio
Re: AES50 splitting
« Reply #4 on: September 10, 2017, 08:58:55 pm »
Coming from the CL and QL world with Dante as the main transport for the past few years, AES50 and others (D-snake) seems so...archaic.  My installs primarily focus on function, so it would take a whole lot to get me to give up Dante which makes life so simple.
CTS-D, CTS-I
AES Full Member
Caleb Dueck
    • Excel AV Group
Re: AES50 splitting
« Reply #5 on: September 10, 2017, 09:30:20 pm »
We do a lot with Yamaha and Dante too.  When I talked with Midas and A&H about this topic (networked vs point to point) in depth, it was a few years back when Dante wasn't as sorted as it is now.  If it were as simple as Dante being "the" protocol, the dLive (for example) would likely have used it.  Look at the latency spec on dLive, is that possible yet via Dante?  How about control via Dante?  Those seem to be two issues that need to be fine tuned yet.
Excel AV Group
Andrew Broughton
Re: AES50 splitting
« Reply #6 on: September 11, 2017, 01:34:48 am »
DL431 is way overkill.
So what if I have a DL16 and want to send the audio from those preamps to 10 M32 consoles? Would I need to put Dante cards in each console?
-Andy
Robert Lofgren
Re: AES50 splitting
« Reply #7 on: September 11, 2017, 02:17:30 am »
If you want point-to-multipoint then Dante would be the best(?) option.
Otherwise you can link the consoles using aes50 and feed each console that way.
Andrew Broughton
Re: AES50 splitting
« Reply #8 on: September 11, 2017, 02:21:23 am »
How do you do that?
-Andy
Mike Sokol
Re: AES50 splitting
« Reply #9 on: September 11, 2017, 06:46:08 am »
I've talked to a Midas engineer about doing this on X32 consoles for my live mixing seminars, and he said you can daisy-chain a dozen consoles via the AES50A and B connections, just like putting two of them together for a FOH/Monitor connection. However, you're still stuck with the first console setting the incoming preamp gain, and all other consoles doing a gain-trim for incoming level. Plus there will be additional clock and signal delays added as you get further down the daisy-chain. His recommendation was to put a Dante card in each console and not mess with the daisy-chain setup.
« Last Edit: September 11, 2017, 06:49:59 am by Mike Sokol »
Mike Sokol
mike@noshockzone.org
www.NoShockZone.org
Pages: [1] 2 3 4   Go Up
Page created in 0.023 seconds with 19 queries.
