Author Topic: QU-32 gain structure  (Read 1373 times)
Stephen Swaffer
« on: September 01, 2017, 12:43:44 pm »
I've set up quite a few wireless mics over the years.  Just swapped out a Shure XLS lavalier system on our QU-32.  Generally, I leave the level at factory presets and just adjust the pre-amp gain. I had a very "tinny" sound-like too much high end.  Noticed just a bit of clipping, so I started backing down the gain-but had to drop it 20 db give or take and get the meter to where it never even went yellow then the sound cleaned up tremendously.
I was of the mindset that if I wasn't in the red, digital should be fine.  What gives?
Steve Swaffer
g'bye, Dick Rees
  • Duluth
Re: QU-32 gain structure
« Reply #1 on: September 01, 2017, 12:57:37 pm »
I'd check the TX sensitivity setting.
From the manual:
« Last Edit: September 01, 2017, 01:00:13 pm by dick rees »
Corey Scogin
  • Birmingham, AL, US
« Reply #2 on: September 01, 2017, 01:09:56 pm »
Is it pegging out the compressor on that channel? Maybe someone screwed with it when you weren't looking.
g'bye, Dick Rees
  • Duluth
« Reply #3 on: September 01, 2017, 02:10:56 pm »
Yeah, the meter pick-off point doesn't show on my screen shot, but it's POST channel processing and PRE mute and fader, so is affected by comp settings.
Corey Scogin
« Reply #4 on: September 01, 2017, 02:48:46 pm »
There are multiple software meters in the channel strip tabs though. He didn't indicate which one he was looking at. I typically look at the one on the input tab when setting gain which most likely is only post-gain.
g'bye, Dick Rees
  • Duluth
« Reply #5 on: September 01, 2017, 03:44:43 pm »
Right.  Doesn't show it on the manual block diagram and I don't have the schematic but it makes sense if you think about it...
Stephen Swaffer
« Reply #6 on: September 01, 2017, 10:09:23 pm »
Which is where I was at.  Compression looked normal-at least the way I usually run it which is set to only start compressing if they raise their voice.
I'll double check tomorrow-but it's sounding good and tomorrow is a wedding so I probably won't experiment til later!
Steve Swaffer
Stephen Swaffer
« Reply #7 on: September 05, 2017, 01:03:24 pm »
Just a follow up-seems like things are never as cut and dried as they seem.  I would up switching the gain switch on the Shure TX from "Mic" back to "0".  I assumed it should be on mic since I was using a Shure MX150 lavalier supplied with the system.  I did that, then turned the channel preamp gain back up roughly 20 db and it sounded good.  We thought we were hearing a little distortion with the switch set on "mic".  Guess I don't understand how turning the pre-amp gain down sounded better if the distortion/clipping was happening in the transmitter.
Steve Swaffer
Scott Helmke
« Reply #8 on: September 07, 2017, 10:52:07 am »
Gain needs depends on how you're using it, which is where the switch comes in handy.
And it's really only a gain switch, since the mic bias power is provided on a different pin and is always on.
Page created in 0.025 seconds with 18 queries.
