Author Topic: Converting amps needed based on ohm change  (Read 1109 times)
David Allred
« on: August 03, 2017, 10:18:07 am »
If a power amp draws 9.5A @ 1/8th power @ 4 ohms, is there a formula to convert the draw @ 8 ohms.  Is it basically 1/2 or 8 and x2 for 2?  Seems a little too easy.
thanks.
Re: Converting amps needed based on ohm change
« Reply #1 on: August 03, 2017, 11:37:02 am »
I like easy....  take it when you can.
On the internet people tell you everything "they" know, not the answer to "your" question.
« Reply #2 on: August 03, 2017, 12:20:31 pm »
Georg Ohm laid it out for you.
Bill Koonce
« Reply #3 on: August 03, 2017, 12:22:40 pm »
I'd think that a lot of that would depend on the amplifier class and power supply. A Class A amp will draw nearly full power regardless of output power, for example. If your amp draws 9.5A @ 1/8 power and that draw was linear, then it would draw 76A @ full power @ 4 Ohms, and over 150A @2. That's one mighty big AC circuit that your amp would need...if input power was linear to output power.
« Last Edit: August 03, 2017, 01:30:10 pm by Bill Koonce »
David Allred
« Reply #4 on: August 03, 2017, 12:55:51 pm »
Thanks, JR, for confirming that I was correct.  (Or at least being the least cryptic.) ;)
« Reply #5 on: August 03, 2017, 01:22:27 pm »
What do you think the odds are that the OP has a class A amp?  ::)
Quote
If your amp draws 9.5A @ 1/8 power and that draw was linear, then it would draw 76A @ full power @ 8 Ohms, and over 300A @2. That's one mighty big AC circuit that your amp would need...if input power was linear to output power.
That was not the OP's question.
The 9.5A was for 4 ohm 1/8th power.   8 ohm 1/8th power would be half that current, all else equal. (not exactly 1/2 because power supply sag would be different but sag at 1/8th power should not be significant for either load..
A current draw @ 1/8th (speaker?) power for a class A amp is not a meaningful spec.  Try not to confuse the issue with superfluous information.
Jeff Bankston
« Reply #6 on: August 03, 2017, 02:43:26 pm »
How would you figure a multi step amp ? I would use an amp meter. But what would be the point of this ?
« Reply #7 on: August 03, 2017, 02:59:51 pm »
You are over thinking this... if 1/8 power for 4 ohm is X...  1/8 power for 8 ohm is half X...  finis.
The point of 1/8th power is for sizing mains ampacity since that is closer to typical consumption than full power.
David Allred
« Reply #8 on: August 03, 2017, 03:58:32 pm »
I found another document on the QSC site.  The PLX3102 is listed 8.8A (not 9.5) @ 4 ohms @1/8th power and 5.7A @ 8 ohms @ 1/8th power.  So not 1/2, but 35% less.
Per QSC... 1/8th power is light clipping, 1/3rd power is very heavy clipping, all using pink noise to simulate heavily compressed program material.
« Reply #9 on: August 03, 2017, 05:49:55 pm »
OK sorry not that simple...
for probably more info than you want the 3102 is a  "2 tier class H technology" amp. What class H means is that they use different voltage power supply rails inside the amp, so for small voltages they can pull from a low voltage rail and not waste all the heat dissipation from a single higher voltage rail. The 3102 is 2 tier so has 3 different power supply voltages inside.
1/8 power @ 4 ohm is a smaller voltage than 1/8 power at 8 ohm. The higher voltage 8 ohm 1/8 power is probably drawing from the bottom and middle rail voltage so less efficient than the 4 ohm just pulling from the smallest bottom rail. So not exactly 1/2 the current.
A class D amp without the multiple PS rails would be more like the linear 2:1 ratio, but the 3102 is not class D or class A.  ::) Sorry.
PS: Since 1/8th power is an important metric for install amps it is likely that the internal power supply voltages were selected to be most efficient at 1/8 power for typical load impedance. Note: these internal voltages are probably different for most efficient 1/8 sinewave power and 1/8 pink noise power. I'll bet they are tweaked for best noise power.
Page created in 0.023 seconds with 15 queries.
