Hello, first off, I'm pretty green to using speakons. We have a small portable rig and want to get rid of the mixture of banana, 1/4" and bare wires by converting everything to speakon. The amp already has speakon outputs. The speakers are Yamaha S115IV. After searching on here the best route for us is to just replace the dishes with a D0604K from parts express. Not sure which chassis connector to use, someone mentioned neutrik has one with spade terminals for a plug and play replacement.
What cable connectors do we use for the speaker cables themselves? All cords are two conductor. Do we use the NL2, needs to have screw type terminals because I can't solder tiny things? It looks like neutrik redesigned the grey ring and now it matches the NL4.
Finally, after someone asked about plugging a guitar directly into a 1/4" monitor jack on the stage at church. We will be converting these as a preventative measure as well. The current fix is keep them covered with gaff tape when not in use. What chassis connector should we use here? Needs to have screw type terminals and mount in a d series panel mount.
I didn't realize there were so many options to choose from.
