Pages: 1 [2] 3  All   Go Down
Author Topic: Tricks for stacks  (Read 4484 times)
Peter Morris
Re: Tricks for stacks
« Reply #10 on: July 08, 2017, 10:26:55 pm »
Any tricks you guys have for building tall stacks?   Let's say 2+ 2x18 subs stacked - gets in the 4-6ft height range.  How to get giant mains (100lbs or more) up that high safely?   I can't imagine OSHA is cool with standing on rack cases or the back of a truck.
Thoughts?
For our small shows I built some winch stands that clip on the back of our double 21" subs.  The subs have a bass that is big enough to allow about 3.2m height and the stands are rated for 100Kg with a 10:1 safety factor; from there we use Penn Elcom stands - 4.0m, then VMB or Work line-array stands 6 m  ... when these are not available we stack on stage decks - the photo shows 6 x Flex Array with 3 subs - one on the deck and 2 under the deck.
We change our inventory some time ago so that anything we may have to lift weighs less than about 40kgs (2 people)
« Last Edit: July 08, 2017, 10:30:16 pm by Peter Morris »
Mark Cadwallader
  • Helena, Montana USA
« Reply #11 on: July 08, 2017, 11:34:18 pm »
Northern Tool and Equipment shows a 500# rated crank-up stacker that lifts to 71". Item no 32849-1756; my print catalog says there is a video available online.  It looks like you would need 4" of clearance under the subs to move the stacker into place.
Chris Grimshaw
    • Grimshaw Audio
« Reply #12 on: July 09, 2017, 07:20:17 am »
Back when I was using Nexo Alpha regularly, we'd just throw the mid-high boxes up.
Stacking the 2x18" subs (orientated vertically) was a 3-man job. One underneath to walk it up once the guys at the sides had got it somewhere near.
Chris
www.grimshawaudio.com
Stu McDoniel
  • Central Wisconsin...USA
« Reply #13 on: July 09, 2017, 07:57:16 am »
Thoughts?
Pickup truck works good.  Set the boxes in the back of the pickup with the gate down.  Back up to the subs and place the boxes on the subs.
Dave Garoutte
  • San Rafael, CA
« Reply #14 on: July 10, 2017, 09:00:55 pm »
Plus you can level out the room.
Events.
Stage, PA, Lighting and Backline rentals.
Chauvet dealer.
Inventor.
« Reply #15 on: July 10, 2017, 09:43:58 pm »
That requires a more manly EQ than that little New Holland.
The Caterpillar D9 "Room Equalizer".
Chris Grimshaw
    • Grimshaw Audio
« Reply #16 on: July 11, 2017, 03:47:03 am »
When I next work as a guest engineer in a venue, that's going on my rider!
Chris
Tom Provenza
« Reply #17 on: July 11, 2017, 06:20:15 am »
Peter,
Would love to see a couple more pics of this solution!
Tom
Tom Provenza
Tim Hite
    • Bad Quail
« Reply #18 on: July 12, 2017, 04:46:39 pm »
. . .from there we use Penn Elcom stands - 4.0m, . . .
So, I just spoke with Penn-Elcom and those SAS stands are a great value, but they are designed for indoor use and there is no wind load rating on them. According to sales rep they would have to have eye-bolts added and guy wires run to be used outdoors.
http://www.penn-elcom.com/default.asp?PN=SAS
Really great concept, though. Wish I had more indoor gigs.
Bad Quail
Sound + Light
Joshua Tree, California
Authorized Dealer for:
RCF, dB Technologies, EV, Turbosound, Tannoy, DiGiCo, Midas,  Earthworks, Sennheiser, Lab.Gruppen, Powersoft, Dynacord, K&M, Mogami, Radial Engineering, Allen & Heath Xone, Anvil Cases, Manley Labs, Rip-Tie
George Powell
    • http://www.gpaudio.net
« Reply #19 on: July 14, 2017, 11:42:37 pm »
Chris
It's on my rider! John Deere last week.
Clair i212
Lab Gruppen
Versarray
VRX
LS9
X32
www.gpaudio.net
State College, Pa 16803
Pages: 1 [2] 3  All   Go Up
Page created in 0.036 seconds with 17 queries.
