Set up for a show today and have had an issue with a couple of SlimPar Hex 6 irc fitting not always completely turning off when faded out.
Setup is Chauvet Stage Designer 50 - Data stream 4 - 2 x 50 ft DMX cables (one to a tree on either side of the stage) - Slimpar Hex 6 - Slimpar Pro W.
When the scene is faded out, sometimes one or other of the Hex 6's stays on at its lowest level (where as the Pro W always turns off completely). I have found that pressing the "Full on" button on the controller, then fading out seems to fix it but that is not practical for a stage show. Also it seems ok when the system first starts.
This is the first time I have had this issue, I have changed cables, re-entered the DMX ch info and am now at a bit of a loss as to what to try next. First show is in 2 days so any ideas would be gladly accepted.
Cheers
