Author Topic: X32 and Reaper  (Read 2117 times)
Aaron Maurer
X32 and Reaper
« on: May 17, 2017, 09:14:17 pm »
So I have been wanting to install Reaper and record some bands just to fiddle around. I have everything installed on the computer the routing is correct per several YouTube tutorials. The computer recognized the console but I cannot get signal from the console to the computer? Example plug a mic into channel 1 and get signal on board but nothing on channel 1 on Reaper. It is most likely something simple?
Corey Scogin
  • Birmingham, AL, US
Re: X32 and Reaper
« Reply #1 on: May 17, 2017, 10:36:28 pm »
Make sure the routing for the Card outputs is set correctly. Either to Local, AES50 A, or AES50 B according to which physical inputs you're using.
« Last Edit: May 17, 2017, 10:45:54 pm by Corey Scogin »
Rob Spence
  • Boston Metro North/West
    • Lynx Audio Services
Re: X32 and Reaper
« Reply #2 on: May 17, 2017, 11:51:09 pm »
What computer? Windoz or Mac?
Corey Scogin
Re: X32 and Reaper
« Reply #3 on: May 18, 2017, 12:04:36 am »
Also check to make sure you have the proper audio device selected in the Reaper preferences under Preferences / Audio / Device.
Aaron Maurer
Re: X32 and Reaper
« Reply #4 on: May 18, 2017, 07:09:34 am »
Program is Windows and I will check the card outputs. Thanks for the suggestions so far.
Erik Jerde
Re: X32 and Reaper
« Reply #5 on: May 18, 2017, 07:34:49 am »
Did you arm the tracks in Reaper?
Michael Grimaila
Re: X32 and Reaper
« Reply #6 on: May 18, 2017, 08:26:05 am »
Check out Drew Brashler's video:
https://www.youtube.com/watch?v=v6a1VvOQoVc
Behringer X32 / X32 Rack
Soundcraft Si Expression 3 / Soundcraft Mini Stage Box 32 / Soundcraft MADI USB & Dual CAT5 & Dual Optical MADI cards
6 x Sennheiser EW300 G3 / Sennheiser EW572 G3 / Sennheiser EW365 G3 / Sennheiser EW352 G3
2 x Yamaha DSR115 / 2 x QSC KW 118
Scott Olewiler
    • 4th Street Sound
Re: X32 and Reaper
« Reply #7 on: May 18, 2017, 09:07:40 am »
Make sure the x32 USB ASIO driver thingy on the PC is actually on if you're using X-USB card.   If I recall from the last time I used Reaper on my laptop  I had to manuuly fire that up each time.
Come to think of it, are you using the X-UF card or the X-USB card? Maybe you have the wrong driver installed on the PC.
If you want to feel more Kick drum turn up the kick drum fader, not the damn subs.
Corey Scogin
Re: X32 and Reaper
« Reply #8 on: May 18, 2017, 12:10:01 pm »
Also, try changing the card output settings to different options and hitting "apply". Cycle between 8in/32out, 32in/32out or whatever. I've noticed a couple of times not getting any audio and when I'd cycle the setting, everything would work fine.
Jean-Pierre Coetzee
  • Gauteng, South Africa
Re: X32 and Reaper
« Reply #9 on: May 18, 2017, 02:25:55 pm »
This only happened to me on our M32 when the USB cable was flacky, could be an X32 thing or a USB cable thing.
Audio Technician
Word & Life Church
- Ivan Beaver
Page created in 0.028 seconds with 16 queries.
