Author Topic: Looking for super simple PC based controller software  (Read 868 times)
Bob Jennings
« on: May 10, 2017, 11:05:41 am »
We have a client running a handful of LEDs and conventional lecos on a loaner NSI dmx console. They have a laptop that they want to use but Titan mobile and the equivalent are beyond the scope of what they can handle in house. Is there a solution out there that will look similar enough to what they are using now to help with the transition?
Thanks,
Bob
Jeff Lelko
  • Cape Canaveral, FL
Re: Looking for super simple PC based controller software
« Reply #1 on: May 10, 2017, 06:54:24 pm »
Hi Bob, have you taken a look at DMXIS?  While it has its limitations it's a very simple interface that isn't intimidating or difficult to approach.  Also, assuming that your NSI board is one of the 2-scene A/B-style consoles this software should look at least a little bit familiar.  There are several users here that can give you a more detailed insight than I can if you have specific questions, but I think this might be right along the lines of what you're looking for.  Freestyler and ShowXpress also come to mind here, but present a different flavor of programming that might not be quite what you want.  Hope this helps!
BrianHenry
  • NJ
    • Mountainside Studios, LLC
« Reply #2 on: May 10, 2017, 06:58:42 pm »
I am a D-Pro user which is the big brother to DMXIS. I don't know the console you listed, but I can answer questions about this software if it is of interest.
James Feenstra
« Reply #3 on: May 10, 2017, 11:30:48 pm »
How many fixtures total?
the Jands StageCL sounds like it may be perfect for you. Not a PC based console, but super simple learning curve. Alternatively if you really want to go pc based, Jands Vista is pretty straight forward and pretty new user friendly.
Elevation Audiovisual
www.elevationav.com
Taking your events to the next level
BrianHenry
  • NJ
« Reply #4 on: May 11, 2017, 12:57:26 am »
Also, is there a budget for this?
Page created in 0.023 seconds with 17 queries.
