Thanks Bob. I get the most interference in a mall nightclub (yes, they took over approximately 4-5 stores, took down the walls, and have the biggest nightclub in a 100 mile radius). The zip is 47715.
Chasing this stuff down can be a royal PITA, for sure.
This is what I get for available frequencies from IAS for zip 47715:
Senn EW300IEM A Bank-Chan 1.01 518.400
Senn EW300IEM A Bank-Chan 6.02 518.900
Senn EW300IEM A Bank-Chan 8.01 520.525
Senn EW300IEM A Bank-Chan 3.02 522.400
Senn EW300IEM A Bank-Chan 7.04 523.900
Senn EW300IEM A Bank-Chan 7.05 525.100
Senn EW300IEM A Bank-Chan 7.08 535.100
Senn EW300IEM A Bank-Chan 7.09 536.900
Senn EW300IEM A Bank-Chan 7.10 541.100
Senn EW300IEM A Bank-Chan 7.11 541.700
Senn EW300IEM A Bank-Chan 5.08 546.025
Senn EW300IEM A Bank-Chan 1.10 546.800
Senn EW300IEM A Bank-Chan 2.10 548.800
Senn EW300IEM A Bank-Chan 4.09 550.100
Senn EW300IEM A Bank-Chan 1.12 552.400
But this past weekend, we were in 40108 - and got the same condition. Some locales, we get no RF hits / others make the system almost unusable.
And for 40108:
Senn EW300IEM A Bank-Chan 5.01 & 7.01 518.300
Senn EW300IEM A Bank-Chan 5.02 520.975
Senn EW300IEM A Bank-Chan 3.01 521.800
Senn EW300IEM A Bank-Chan 5.04 & 7.06 525.500
Senn EW300IEM A Bank-Chan 5.05 532.000
Senn EW300IEM A Bank-Chan 3.05 533.400
Senn EW300IEM A Bank-Chan 5.06 533.900
Senn EW300IEM A Bank-Chan 5.07 540.700
Senn EW300IEM A Bank-Chan 5.09 549.900
Senn EW300IEM A Bank-Chan 5.10 550.300
Senn EW300IEM A Bank-Chan 5.11 551.000
Senn EW300IEM A Bank-Chan 4.11 553.500
So, the RF coordination for these two zip codes is completely different - The only frequency that works in both locations is 518.900
I will have to get back to you on the frequencies. I've done some many scans over the past couple of weeks, I have no idea where I'm at the moment.
I've used WWB in the past to coordinate.
I've not tried to take 1 transmitter out of the rack yet - we primarily get the RF hits on the road, and there is little time to troubleshoot. ...other than freq scans.
I think that maybe the only way to get ahead of the game involves a few items.
First, use software before you head out for the particular zip code. That way, you've at least got a valid coordination before you get there.
The 2nd item is to have a frequency scanner like the TTi, so when you arrive, you can see if there are rogue RF sources in the venue. I've had situations where everything was coordinated and had massive interference. My TTi showed a bunch of activity with all my transmitters off. It turned out that the venue had a number of 600Khz devices on - they weren't need, and, when they were turned off, everything was good.
If when you turn on your IEM packs without anything else on and they show RF, that's a telltale sign for sure...
Lastly, I think you're going to have to take things apart and test... A major PITA, I know, but sometimes, you cost yourself more time and aggravation than just doing it.
Yes, I use the AC2 combiner.
I'm wondering if it is going bad - cables are built into the chassis - or if I have a transmitter that is leaking some stray RF??
Either of those things are certainly possible.
I wish I'd written everything down I've tried - I'm not sure there is anything left to try. LOL
I've been in that boat! I think starting with a known good coordination for each zip code is likely to yield the most immediate positive results.
Best regards,
Bob
