Author Topic: PowerCon 32A to L14-20P?  (Read 2437 times)
Andrew Henderson
  • Lab Lounge
    • http://www.getlostinsound.com
« on: December 17, 2016, 07:20:05 am »
I'll soon have an amplifier that has a PowerCon 32A connector (Danley DNA20K4).
I've gotten good info from the manual and from other threads about how to run this on a standard 120 "Edison" outlet when needed.
Our Power Distro has L14-20R connections. For me to run this amp at 240V, Is it safe/legal for me to make a 3-wire cable that goes from L14-20P (4-conductor) to PowerCon 32A (3-conductor), and just leave the neutral terminal on the L14-20P disconnected?
Thanks in advance. I don't have experience with not having a neutral conductor.
Stephen Swaffer
Re: PowerCon 32A to L14-20P?
« Reply #1 on: December 17, 2016, 10:15:11 am »
If you think through the entire circuit from the breaker panel to the 3 wire powercon you will get your answer.  If I ( I'm a licensed electrician so been here done this) install a 3 wire 240 volt receptacle I usually come out of a panel with 2 "hot" wires and a ground-leaving no connection to the neutral in the panel.  If I install a 4-wire receptacle, I run a ground with it. I can run a neutral as far as I need it-but if it is not needed, I simply leave it disconnected.  It doesn't matter whether the electrician doesn't run the neutral from the panel to the receptacle, or if you decline to run it from the receptacle to the equipment.
I would NOT recommend not including a neutral if the load end of your cable has a 4-wire connector-in that case it would be possible to connect some equipment that needs a neutral.
The connected equipment determines if a neutral must be connected.
Steve Swaffer
Andrew Henderson
  • Lab Lounge
« Reply #2 on: December 17, 2016, 10:39:00 am »
Ok, I think that makes sense. Every time we have connected our split phase (120/240v) distro, we have connected to the neutral and ground separately at the panel. Up until now, we haven't actually had any 240v equipment. We've just used the 4-wire runs for splitting into two "legs" of 120v.
The cable run to the amp rack will still be 4-wire, but the amp itself has a 3-conductor power input. The cable I would make would just be a short jumper, a dedicated power cable for that amp.
Mike Sokol
« Reply #3 on: December 17, 2016, 10:51:42 am »
I would also suggest you use SOOW (Hard Service Cord rated for 600 volts) rather than SJOOW (Junior Hard Service Cord rated for 300 volts) for any 240-volt adapter cables. That will help keep the AHJ happy.
Mike Sokol
mike@noshockzone.org
www.NoShockZone.org
Andrew Henderson
  • Lab Lounge
« Reply #4 on: December 17, 2016, 11:28:59 am »
Will do! I have some 10 gauge SOOW laying around. Thanks for the guidance, guys.
Dustin Corey
« Reply #5 on: April 11, 2017, 08:45:53 am »
I have been reading several 240v threads but want to verify it's safe to run 2 hots and a ground into the DNA 20k. I will be having an electrician add a new outlet for this amp and need to be sure to tell him what I need. The main breaker panel is only about 20ft away.
Also which plug will ship with the DNA in the US? L6-20 I'm assuming? Hoping to have the power ready when it comes in.
Thanks!
« Reply #6 on: April 12, 2017, 10:16:26 am »
Thanks!
Yes, the plug it comes with is an L6-20.
It has 2 hots (for 240V) and a ground.
When it is run on 120V-one of the “hots” is actually the neutral.
You don’t need to do anything on the amp-it will “self adjust” to either voltage or 208V.
Just make sure it is not higher than 260V.
In the shop we have adaptors that are Fmale L6-20 to  regular Edison outlets, just so we can plug them in anywhere
Dustin Corey
« Reply #7 on: April 12, 2017, 02:37:13 pm »
Perfect, thanks!
Josh Evangelista
« Reply #8 on: August 05, 2017, 09:15:50 pm »
Ivan. Is there a reason why Danley has chosen an L6-20p vs an L5-30p?
« Reply #9 on: August 06, 2017, 09:54:15 am »
The L5 is not listed for 250v operation.
Page created in 0.024 seconds with 19 queries.
