Author Topic: PL380 question  (Read 1823 times)
brian casterlin
PL380 question
« on: December 13, 2016, 05:23:53 pm »
I have a Pl380 and its run on a 20amp breaker lately it pops the break during turn on, I reset the 20amp breaker and its fine.   QSC says its soft start system shouldn't pop breaker.   I tried this at  5 different venues that I used this on a dedicated 20 and never a problem till just last month.  I only run loads of 4 and 8ohms.      Strange because the amp runs like a champ after.
Re: PL380 question
« Reply #1 on: December 13, 2016, 05:43:45 pm »
Maybe the soft start circuit is not starting soft.
On the internet people tell you everything "they" know, not the answer to "your" question.....  http://circularscience.com/
brian casterlin
Re: PL380 question
« Reply #2 on: December 13, 2016, 05:53:18 pm »
that's what I'm thinking, but sometimes it's just fine and works. I may have to fork over the 70$ to ship it back to qsc for some bench testing. What's weird is I can shut it off and start it up 10 min later without an issue.
PhilipGoldworth
Re: PL380 question
« Reply #3 on: December 22, 2016, 07:57:53 pm »
Not strange at all. The 2nd time you start the amp, you've already charged the power supply storage capacitors.
brian casterlin
Re: PL380 question
« Reply #4 on: December 23, 2016, 08:54:16 pm »
I figured that but it was working fine at all these spots now, no so much so.  I wonder what the startup surge is on these.  A friend who has like 16 of them for tour duty on subs does not have an issue but they are on distro boxes with 30amp breakers. He seems to think I have weakened all the breaker in the places I use this at :)
Dennis Wiggins
Re: PL380 question
« Reply #5 on: February 18, 2017, 07:11:19 pm »
I'm confused.  Is it only when you use the same specific breaker (as in your distro, that you have control over) that itrips, or is it with any feed (not under your control) with a 20A breaker?
-Dennis
John Rutirasiri
Re: PL380 question
« Reply #6 on: February 18, 2017, 11:55:59 pm »
Did your hear the relays on the amp prior to circuit breaker tripping?
Sound/Lighting/Corporate A/V
Page created in 0.036 seconds with 19 queries.
