I have a hard time understanding the statement, speaker is notorious at producing distortion. I don't know there is such a speaker exist...Could you elaborate it?
It depends on how loud the distortion is and how loud it is in relation to the fundamental.
Here is how to do a simple test. Use a sine wave generator and start around 60Hz or so and turn up the level to a decent SPL.
Now start to lower the freq-without changing the level (assuming the generator has a constant voltage output)
At some point you will hear the freq go up while you are lowering the freq.
This is point at which the distortion is much greater than the fundamental.
The fundamental is still there, but you can't hear it because of the distortion (higher freq) present.
There is one manufacturer that makes claims about being able to go really low. But at an octave or more ABOVE the low freq in the spec-the distortion is FAR greater in SPL than the fundamental.
So yes it CAN reproduce those freq, but not at any level that is useable.
They even say so in a little hidden area of the website.
But IN REALITY-EVERY speaker ever made can easily reproduce 1Hz, even little tweeters.
Now whether or not you can hear it is a COMPLETELY different story.
And yes-there are plenty of speakers that can reproduce 20Hz at plenty of level so you can hear it clearly. It does not really need to be that loud either.
But most people have simply not heard these speakers, so therefore they say it can't be done. But they are wrong.
You can easily hear down quite lower than 20Hz-AS LONG AS the signal reproducer is still clean.
