Author Topic: mutual coupling tk  (Read 939 times)
tkroeker
  • Guest
mutual coupling tk
« on: September 30, 2016, 01:42:19 pm »
So one piece I'm missing is this.
when two speakers couple, is it at Hz above or below the 1/2 wavelength?
i.e. ( roughly)
two 18's
80 Hz = 14 feet
1/2 wavelength = 7 feet
if the two 18's are under 7 feet apart will they couple 80 to 500,, or 80 down
  • Old enough to know better
  • Audio Plumber
Re: mutual coupling tk
« Reply #1 on: September 30, 2016, 01:50:04 pm »
i.e. ( roughly)
two 18's
80 Hz = 14 feet
They stop canceling and begin to couple at frequencies whose 1/4 wavelength is larger than the driver spacing. You get summation over a 1/2 wavelength range, but it is plus/minus 1/4 wave around zero phase offset. Since there is no minus offset involved in driver spacing it is only 1/4 wavelength, a 1/4 wavelength being 90 of phase offset.
« Reply #2 on: September 30, 2016, 05:09:09 pm »
They couple as the freq goes LOWER.
The spacing is the UPPER limit.
Because as the freq goes lower, the wavelengths get longer, so they get "acoustically closer" as the freq goes down.
tkroeker
  • Guest
« Reply #3 on: September 30, 2016, 05:16:08 pm »
awesome thanks
Page created in 0.038 seconds with 23 queries.
