Author Topic: M7CL questions  (Read 2052 times)
1
M7CL questions
« on: March 11, 2016, 04:56:35 pm »
Hi,
1. There is a vocal microphone on channel one that is not assigned to a DCA. There are also two other vocal microphones (ch 39 and 40) assigned to a DCA. When ch 39 and 40 are off, ch 1 is on, and I raise the DCA, it changes ch 1. Is it supposed to do that?
2. I am trying to send a mix to an Aviom mixer but there is no sound. The mixes that are already sent are coming through; what am I doing wrong?
Thanks!
John Penkala
Re: M7CL questions
« Reply #1 on: March 11, 2016, 05:33:02 pm »
Hi,
Thanks!
It's been a couple of years since I've been on an M7 but anyway:
Check your routing on Channel 1 and make sure its not routed to a subgroup/mix or linked to another channel that is assigned to the DCA.
You have to assign the card output in "Outport Setup" in the Settings menu.
jason misterka
Re: M7CL questions
« Reply #2 on: March 11, 2016, 05:53:15 pm »
Hi,
Thanks!
No offense but are you sure that the center logic faders are set to control DCA and are not set to control fader bank 1-8?
Jason
Re: M7CL questions
« Reply #3 on: March 12, 2016, 06:06:34 am »
Hi,
I think Jason has the right answer.  Was it moving the Ch 1 fader, too?
1
Re: M7CL questions
« Reply #4 on: March 26, 2016, 07:50:10 pm »
Aviom solved.
Ch 1 is the only channel in use on that bank and there are 5 DCAs --
No links --
Everything is sent to the monitors (mix 1); does that have something to do with it?
Page created in 0.057 seconds with 21 queries.
