What about 8?
I need to collapse the vertical.
When you stack the BC218-the pattern becomes even more reduced behind (due to the larger boundary.)
When you start to stack subs (or space them out vertically) the pattern will narrow in the vertical.
So with 8,the best configuration would be 2 wide (so the eye is in the middle) and 4 tall-so the eyes would be vertically lined up
You will get a narrowing of the vertical pattern (due to the sub spacing) a donut shape- if you will, and huge rejection in the rear (due to the "solid wall") and the "barn door" effect.
Plus you could probably stop somebodies heart or at least suck the air from their lungs if they were on axis.
