Author Topic: Cleaning Duraflex UPDATE  (Read 2300 times)
Alex Rigodanzo
  • U.P. of MI "M Go Blue!"
    • Next Myle band
« on: August 12, 2014, 06:08:29 pm »
Just picked up a pair of SRX722's.  Looks like the po used Armor All or something similar on the cabs and they're all streaky.  JBL manual says clean with a dry cloth, but also to use a grease remover if cleaning for painting.  So what's the thing to clean these with?  Dawn?
« Last Edit: August 16, 2014, 03:07:18 pm by Alex Rigodanzo »
I'm not single, I'm in a long-term relationship with Freedom
Re: Cleaning Duraflex
« Reply #1 on: August 12, 2014, 06:11:40 pm »
A powdered household cleanser like Spic 'n' Span.  Use a scrub brush to get into the nooks and crannies and follow with a clear water rinse to get the detergent off.
Are you going to repaint them?  I'm not sure anything will fix the streaking if it's penetrated the coating.
Alex Rigodanzo
    • Next Myle band
« Reply #2 on: August 12, 2014, 07:23:32 pm »
Probably not, just want to give cleaning a try.  They're in pretty good shape but must have been a little faded or something and he wanted to "blacken" them up to sell.  Very few nicks and no dents in the grills so fairly nice.
Bob Leonard
  • Boston, MA USA
« Reply #3 on: August 13, 2014, 12:33:46 am »
Windex does a very nice job.
BOSTON STRONG........
Proud Vietnam Veteran
John Fruits
« Reply #4 on: August 13, 2014, 04:35:01 am »
If you have  Dollar Tree Store near by you might invest a buck in their "Absolutely Awesome, as seen on TV" degreaser.  This stuff works great at removing anything greasy.  It comes in two sizes, the spray bottle or the larger refill size, can't beat it for a buck.
"The music business is a cruel and shallow money trench, a long plastic hallway where thieves and pimps run free, and good men die like dogs.  There's also a negative side."-Hunter S. Thompson
Scott Harris
  • Subwoofer forum
  • Worcester, MA
    • Running Sound
« Reply #5 on: August 13, 2014, 10:29:28 pm »
Or you could go in the other direction and get some armor all type wipes and try to blend the streaks out.  If you have streaks on the bottom surface you cold try it there first to make sure it works on a non-visible surface.
Chuck Simon
  • Pittsburgh, Pa.
« Reply #6 on: August 14, 2014, 12:10:43 am »
Be sure and clean it before you apply the Armor All.
Alex Rigodanzo
    • Next Myle band
« Reply #7 on: August 14, 2014, 11:26:55 pm »
I'm not applying Armor All. I want to get that off. If I was going to use anything, it would be 303.
Alex Rigodanzo
    • Next Myle band
Re: Cleaning Duraflex UPDATE
« Reply #8 on: August 16, 2014, 03:10:46 pm »
I thought I'd share what I did in case it might help someone else down the line.  Rather than try to clean the stuff off, I thought I'd try to even it out to remove the streaks.  I used my 6" polisher with a clean, dry wool bonnet and buffed the cabinets.  It worked great.  No more streaks and the better cabinet came out looking damn near brand new.  The other is quite acceptable for whatever age these are.  So if you're thinking about applying some product to bring back the black but are concerned about getting even coverage with the texture, this did the trick.
Jonathan Johnson
« Reply #9 on: August 18, 2014, 02:07:55 pm »
Glad you found a solution.
My go-to cleaner is Simple Green. It's fairly gentle, but works well on removing oily or greasy grime.
For more "durable" gook such as adhesive or permanent marker, I like De-Solv-It (pretty much pure citrus oil), but you want to be cautious on painted or finished wood surfaces (baked enamel or anodized is OK, but it may soften other finishes). Don't use De-Solv-It on unfinished wood.
Page created in 0.046 seconds with 21 queries.
