Author Topic: alternative to fast fold for rear projection?  (Read 1870 times)
Adam Whetham
  • Grand Forks, ND
« on: April 21, 2014, 04:35:35 pm »
Has anyone seen any alternative to the Da-Lite style fast fold frame/screen system for portable rear projection?
I thought i had something with Vuetec and their Retracta Vu system, but after talking to them the rear projection option is discontinued.  :(
http://www.vutec.com/retracta_vu_pro_traveller.html
Looking for a screen size like a 16:10 ratio 67"x107"
-I practice safe excursion on the weekends.
"If you think it's expensive to hire a professional to do the job, wait until you hire an amateur." -Paul Neal "Red" Adair
Sam Feine
Re: alternative to fast fold for rear projection?
« Reply #1 on: April 21, 2014, 04:36:55 pm »
We use draper stage screen for our larger screens and it is modular which is alway nice for smaller screens.
Electro-Acoustic Engineer at Community Professional Loudspeakers
Sean Hayes
« Reply #2 on: April 21, 2014, 04:46:00 pm »
We use Stumpfl Monoblox for all of the screens in our rental inventory. High quality and great customer service. They have an office in the Chicagoland area.
Sean T. Hayes
Adam Whetham
  • Grand Forks, ND
« Reply #3 on: April 21, 2014, 05:18:38 pm »
Hmmm yea, was hoping to find something like the vue tech where it wasn't a frame with screen pinned on. More of a pull up from the floor design but rear projection.
Thanks though!
Jonathan Kok
  • Toronto
« Reply #4 on: April 25, 2014, 04:46:58 pm »
Thanks though!
You could make your own. Take a standard manual screen (rear project surface), mount it upside down in a box. Bolt a couple of vertical posts on hinges behind the screen and modify the bottom (now top) bar of the screen to accept pins from the vertical posts. Raise screen, swing up posts, insert into pin, done.
Stability would be an issue, so you may need to add a couple of 'outrigger' bars to the vertical posts.
You may need to remove the brake from the screen for it to work inverted.
Page created in 0.05 seconds with 24 queries.
