Author Topic: Boss Vocal Pedal  (Read 7865 times)
  • Old enough to know better
  • Audio Plumber
Re: Boss Vocal Pedal
« Reply #10 on: January 08, 2014, 01:47:04 PM »
No complaints here for under $100, http://www.sweetwater.com/store/detail/Split1x2
The iso splitter box is great if you are sending the signal to 2 different places, but in the case of sending 2 versions of the mic to the same console a simple FMM twofer will work as well.
Dave Bednarski
« Reply #11 on: January 08, 2014, 02:10:49 PM »
For educational purposes/benefit, what is the difference between sending 2 versions of the mic to the same console or two separate consoles?
Cosmo
  • Northern Colorado, USA
« Reply #12 on: January 08, 2014, 02:45:47 PM »
In a perfect world, none.  But in real situations, a monitor console (for example) may be powered from a different AC source than the FOH console, so you *could* develop a ground loop, a.k.a. hum.  Sending one signal through a transformer eliminates the loop.
If a man does not keep pace with his companions, perhaps it is because he hears a different drummer.  Let him step to the music he hears, however measured or far away.  - H.D. Thoreau
  • Audio Plumber
« Reply #13 on: January 08, 2014, 04:41:04 PM »
In the case of the vocal pedal being discussed, it lets you set the gain and eq for the effect separate from the clean mic. Since the pedal currently reduces the gain significantly this would be an advantage.
Perhaps a better option is a switch box which lets the artist decide when to use the effect and when not to. This takes that responsibility off the soundman. Whirlwind among others makes a footswitch that does this.
« Last Edit: January 08, 2014, 04:43:25 PM by Mac Kerr »
Tim Perry
  • Utica-Rome NY
« Reply #14 on: January 09, 2014, 02:08:43 AM »
The VC-20 or the RC-30?
Page created in 0.023 seconds with 24 queries.
