Author Topic: Short throw projector input  (Read 5356 times)
Jonathan Kok
  • Toronto
Re: Short throw projector input
« Reply #10 on: March 27, 2013, 02:08:19 pm »
I knew I had seen a 100+" display somewhere. Thanks.
Unfortunately I think the architecture was planned out before technology was thought about. My job is to find out if there is a viable solution to the problem now.
Cluster of TV's isn't going to pass the "Pretty" test of the higher ups. We are looking at getting some 70-80" displays by the sounds of it now, but a projection option is still being discussed.
Ceiling mount screen does not block out any sun. The room is two stories tall. Screen is mounted in the ceiling.
Frankly, short-throw projection is NOT viable in a room like that.  You mention 'space behind the screen'; if you're thinking 'rear projection', that's basically right out.  At least, not during daytime.
As others have mentioned, a single 100+" monitor, or 2x2 arrayed monitors, are the only real choices.  Of course, using either of these is going to make your 8K projector look terrible in comparison.  Array the 2x2's on a Chief LVM, or similar cart, and you're laughing.  a 2x2 array of 47" monitors would run you ~ $20,000, with the stand.  Any projector/screen combo capable of producing something even close to the brightness/contrast of that will run you more.
