Pages: 1 [2] 3 4 ... 6   Go Down
Author Topic: Direct box with XLR input  (Read 28157 times)
Geoff Doane
  • Halifax, NS
Re: Direct box with XLR input
« Reply #10 on: February 13, 2013, 01:44:13 PM »
BSS Audio AR-133 Active DI Box @ 179 each ($360)
EWI DBRC-2A 2 channel passive direct box @ $49.50
The BSS input is not balanced, and has unity gain unless you switch in the pad.  It seems like a lot of money to spend for what is essentially a pad.
The trouble with cheap passive DIs is they have small transformers which saturate easily at low frequencies and high levels (exactly the situation you will have will a DJ).
I'd look into a couple XLR barrel pads (you can make your own), and I think we discussed this a little while ago:
http://forums.prosoundweb.com/index.php?topic=141375.0
GTD
P.S.  Just discovered the link within the link above is broken.  This one works:
http://audiopile.net/products/Adaptors_Connectors/Adaptors/AP_XLR_PAD/XLR_PAD_cutsheet.shtml
« Last Edit: February 13, 2013, 01:51:53 PM by Geoff Doane »
Joseph D. Macry
  • Austin TX
« Reply #11 on: February 13, 2013, 02:09:19 PM »
I am looking for suggestions on  Direct boxs to pad down pioneer Dj mixers.  The newest pioneer djm mixers do not have a 1/4 inch master out. They only have a XLR output and RCA output. So I either need a DI with a XLR input or a RCA input.  The mix wiz pad does not pad it enough when the dj mixer is maxed out.
I found models
The EWI could also be used for people that give me a 1/8 source or RCA source
rig
Mixwiz 16
Drive rack pa ( over easy limiter)
DBX for brick wall limiter
QSC KW 153 / Kw18
KW12 monitors
Radial ProAV1/2
http://www.radialeng.com/r2011/proav.php
Joseph Macry,
Austin, TX
Patrick Tracy
  • Boulder, CO, USA
    • Boulder Sound Guy
« Reply #12 on: February 13, 2013, 02:11:38 PM »
That's effectively the same as adapting to TRS and it doesn't solve the (presumed) ground problem. If it's just a level matching problem then the best solution is to connect the line level balanced signal to a line level balanced input. Why make things more complicated than they have to be?
g'bye, Dick Rees
  • Duluth
« Reply #13 on: February 13, 2013, 02:20:40 PM »
If you're going XLR out from the DJ mixer into the MixWiz XLR ins, you're going into a mic level input and then using the onboard pad to knock it down.  But if you use an XLR>TRS cable out of the DJ mixer into the line input of the Wiz and then using the pad, you'll get closer to a usable level.
I'll check the schematic to make sure, but I think this should do it for you.
Otherwise, Switchcraft makes a stereo DI with TS and RCA inputs.  Two models, one with Jensen transformers for about $380 and a cheaper one.
Edit:
Yup.  The pad is in line with either input, so you get the inherent signal diminution plus the pad on the line input.
« Last Edit: February 13, 2013, 02:24:19 PM by dick rees »
Frank DeWitt
    • LBP DI Box
« Reply #14 on: February 13, 2013, 02:32:09 PM »
Two sources.  http://www.jensen-transformers.com/pixxpoxx.html  Jensen will put one of these together with XLR in and any out you want.  The only down side is no ground lift.
I will build you one (I make and sell DI boxes.) It will have a TRS input wired balanced signal on Tip and Ring. You will need a XLR to TRS cable.   Clock on my Sig for details.
Not to Code
Patrick Tracy
  • Boulder, CO, USA
    • Boulder Sound Guy
« Reply #15 on: February 13, 2013, 03:20:59 PM »
And quite possible nothing else.
g'bye, Dick Rees
  • Duluth
« Reply #16 on: February 13, 2013, 03:56:43 PM »
Yup.
Running the XLR outputs from the DJ mixer into the line inputs using the XLR>TRS cables and using the 30dB pads on the Wiz should give you 45dB of reduction.  If that's not enough .......
TURN THE MIXER DOWN.
Andre Vare
  • Hamilton, ON Canada
« Reply #17 on: February 13, 2013, 04:17:07 PM »
This makes the most sense and is the cheapest.
Andre
Nate Armstrong
« Reply #18 on: February 13, 2013, 04:22:09 PM »
I looked in the mixwiz manual
XLR input sensitivity -60 to +10 db
TRS input sensitivity -40 to +10 db
Pad in (MIC or LINE) >10k ohm, -20dB
The Pioneer DJ mixer has a +22 DB sensitivity
I would think with the pad activated on the MW I would only have a +2 db at the line input of the Mixwiz  but it seems way hotter than that.  I have to turn the gain almost all the way off ( -8 db ) to not have a clipped signal when they red line the pioneer.
Edit
I just realized something .. There are 2 diagrams on the MW trim pot  -10 to + 40 and 10db to +60
I have been looking at the TRS diagram and not the XLR diagram this entire time. So when I thought I was at 0DB i was actually at 20 DB because I was using XLR mic input    ( wow i feel dumb )
GTD
I rather not purchase 2 more DI's if not needed especially at such a high price.  Really all I need is a Pad
Can I get some advice on what pad to get
I am leaning towards the 30 DB pad  would that be to much ?
The Pioneer mixer is rated at +22 DB
I may not need a Pad at all if I use a TRS jack. I am going to test it when I get home. I dont have a DJM but i still should be able to replicate it..
Basically I just want a clean close to 0 DB signal into my board and a clean signal out to my PA
What do I need to accomplish that ?
Nate Armstrong
« Reply #19 on: February 13, 2013, 04:29:57 PM »
To me it seems like Dick ,Patrick and frank are all correct and I just need a XLR to TRS to plus the built in Pad on the mixer.  Like I stated early I will test this sometime this week.
Glad I asked instead of just going out and buying expensive Di's
Pages: 1 [2] 3 4 ... 6   Go Up
Page created in 0.02 seconds with 25 queries.
