Author Topic: TVs for Church Plant?  (Read 946 times)
Bryce Swanson
« on: January 29, 2013, 10:24:34 pm »
Good Evening All,
We are in the final stages of buying our equipment for our church plant, and due to the facility we have opted to go with 2 50'' TVs.  The room is 40x40 with 120 chairs.  A few questions
Are 50'' TVs big enough?  We are thinking of doing 2, one on each side of the stage.
Which TVs are durable, and are rugged enough to withstand packing\unpacking every week and moving around in a trailer?
Any other thoughts on TVs?
Thanks,
Bryce Swanson
Innovate Church
Jordan Wolf
Re: TVs for Church Plant?
« Reply #1 on: January 29, 2013, 10:54:20 pm »
Good Evening All,
Thanks,
Bryce Swanson
Innovate Church
Bryce,
I set a room with two 80" widescreen LED TVs to replace the screen/projector package in a room of similar size to what you described…and I felt that they should have been larger.
See picture.  I'm about 5' 7" tall, by the way, so my arm-span is about that same distance.
Jordan Wolf
Brad Weber
  • Marietta, GA
« Reply #2 on: January 30, 2013, 06:44:12 am »
Image viewing, especially for text, is greatly a function of the image height.  A typical 16:9 format 50" flat panel display provides an image just over 2' high, which is probably good for viewing from a maximum of 12' to 20' depending on the content.  So I'll echo Jordan's comments that while a 50" display may sound like it would be big, it is likely much too small for that space.
What I tell people to do is go to an electronics store and stand the distance from the screens that your furthest viewer would be from your screen and think about what you plan to display on your screens.  You might be surprised how small those images look at that distance.
Well, I'd say stick with professional models from manufacturers like LG, NEC and Samsung.  Avoid consumer models whose warranties exclude any commercial or professional use,  And get some good quality flight cases and some good quality, heavy duty stands, both of which are probably going to represent a substantial cost on their own.  And if their use is critical then you might want to purchase three or four displays so that you have a backup or two.
What are the sources for the images and how do you plan to get them to two displays?  How high do the displays need to be in order to be viewed by everyone and how tall of a stand does that require?
« Last Edit: February 03, 2013, 09:16:18 am by Brad Weber »
Alex Donkle
« Reply #3 on: February 03, 2013, 07:15:02 am »
Typical rule of thumb is to measure the distance between the screen and the furthest viewer, and then divide by 6. That number should be roughly the image height of your screen. (Or sometimes use /8 for larger content, for /4 for more detailed content), and keep no one should be "off-axis" off the screen by more than 45 degrees to either side (the letter "O" starts to look like "I" once you are too far off-axis)
Brad Weber
  • Marietta, GA
« Reply #4 on: February 03, 2013, 10:49:27 am »
The image height being 1/6 the distance to the furthest viewer guideline is for typical computer graphics with 1/8 for general video viewing and 1/4 for critical viewing such as CAD, spreadsheets, etc.  However, I have found that because they are often able to work with fewer, larger characters on the screen or presenting more environmental graphics that many churches can get away with greater viewing distances.
The larger font text also helps with some of the off-axis issues you noted.
Bob L. Wilson
« Reply #5 on: February 03, 2013, 06:36:22 pm »
I am generally a buy the best and keep it a long time kind of guy, but not when it comes to displays. I think the best way to resolve the tension between cost and "we should upgrade" is to buy consumer displays and resell them every year, or two at the most. Displays have been getting bigger, better and cheaper at a fierce rate, so one or two sizes below the largest model will generally be an area of the price sheet that has already been heavily discounted. We have had excellent luck with Sharp products all around our campus over the last 10 years, but of course we aren't roading them.  I suspect we are about three years away from, better than current HD, 12'-15' displays at commodity prices. Projector based setups will become a thing of the past soon there after.
Brad Weber
  • Marietta, GA
« Reply #6 on: February 05, 2013, 01:39:00 pm »
I had a Client that thought this way until they had spent more in a year on consumer devices that had failed and were not warrantied in the application than if they had simply purchased commercial units to start with and eventually they replaced everything with commercial units.  But what was a critical factor in that application, and may be in many others, was the impact of a failure.
One aspect of that is the potential effect of any failure or problem on the intended purpose or use of the displays.  Is any failure or possible loss of use of a more critical nature?  Another factor can be how any replacement will be funded and if that funding will be readily available.  In some cases it may be easier or more practical to get greater initial funding than it is to get ongoing funding for repairs and replacement.
Lee Douglas
  • 47.662615, -116.756954
« Reply #7 on: February 05, 2013, 10:55:27 pm »
Bryce,
I give up.  What's holding that display up??!!   :D
Just "Good Enough" isn't...
Bob L. Wilson
« Reply #8 on: February 06, 2013, 04:50:23 pm »
We are talking about a display in a church not an anesthesia machine. I realize long warranties give a system integrator or contractor the easy out when there is a problem but warranty length has nothing to do with quality or reliability. A Kia is not less likely to fail or last longer than a Honda just because it has a longer warranty.
Brad Weber
  • Marietta, GA
« Reply #9 on: February 08, 2013, 09:38:08 am »
I had the impression these displays were the primary displays and not ancillary displays, thus I don't know we can assume how important they are.  However, my point was simply that the importance of the displays working or being addressed under warranty if something fails can be a factor to consider.  If you don't feel it is a relevant factor in your situation that does not mean everyone else will have the same situation or perspective.
I was also not addressing the duration of the warranty but whether one exists at all.  Some consumer product warranties expressly exclude essentially anything other than residential use, thus meaning use in church may be excluded from warranty coverage.  Some people seem to believe that it being related to a church makes it acceptable to misrepresent the use and that is a choice each person or church must make but I personally do not share or endorse that perspective.
Also related to the application is the actual use.  If the displays are used a couple of hours a day then that may be more like a typical use for which consumer products were designed.  If the displays are used 24/7 then that is probably well beyond the intended use of a consumer display and likely why such potential use may be excluded from warranty coverage.  Just another potential factor one may want to consider.
I do not understand how "long warranties give a system integrator or contractor the easy out when there is a problem".  If by "easy out" you mean things like being able to get immediate replacements rather than having to first have the display checked out by the manufacturer or potentially having the manufacturer pay for their labor rather than having to build that into their cost then that may be true but otherwise I am not sure what you mean.
Page created in 0.114 seconds with 24 queries.
