Author Topic: Mackie DL1608  (Read 726 times)
Steve Garris
Mackie DL1608
« on: January 22, 2013, 05:07:15 pm »
I apologize if this has already been discussed. I've been reading various forum posts that mention this mixer, its pluses and shortfalls. I have an opportunity to try one at an upcoming gig, but I now have some reservations.
The post eq/comp aux send is my biggest complaint. I read that this issue could be fixed with a software upgrade, and might happen soon. It really should be switchable on all 6 auxes, if that is possible. But man would I love to leave all 300 lbs of my mixer, processing gear and 100 ft snake at home (just guessing on the weight).
I believe the only way to safely use this is to have no less than (2) ipads at the gig. This provides a backup just in case. I will also be very careful picking out and securing the router. I've read about the global phantom power - not an issue for me.
Aside from the above, any thoughts on this mixer? When I first started reading about it I was ready to sell my gear and convert to the 1608, but the aux sends need pre-post choices (hopefully a firmware upgrade?). My upcoming gig is a Metal hair band, so I can't compromise on my monitor mix.
dick rees
  • St Paul MN
Re: Mackie DL1608
« Reply #1 on: January 22, 2013, 05:13:54 pm »
Mackie "mixer" : $ 980
iStuff:              $1100
Total:          over $2K
I'll keep carrying the weight.  Besides, I put it on wheels.
Jonathan Betts
    • http://www.facebook.com/pages/JLB-Sound-and-Production/156817657745906
Re: Mackie DL1608
« Reply #2 on: January 22, 2013, 05:19:28 pm »
I really like mine. I have done over 20  shows using as a FOH mixer with no issues.
My expenses:
Mackie DL $900
I Pad $300
Airport Express$60
« Last Edit: January 22, 2013, 05:23:01 pm by Jonathan Betts »
dick rees
  • St Paul MN
Re: Mackie DL1608
« Reply #3 on: January 22, 2013, 05:31:17 pm »
My expenses:
Mackie DL $900
I Pad $300
Airport Express$60
How long does the iPad  battery last before you have to buy a new pad?  Doggone planned obsolescence/non-user serviceable iJunk anyhow.  How long before Apple changes their design so you'll have to spend even more money to get something that works as well as what they used to sell before their "upgrade"?
And the OP wants 2 iPads for redundancy/backup........
Scott Harris
  • Marlborough, MA
    • Running Sound
Re: Mackie DL1608
« Reply #4 on: January 22, 2013, 05:39:09 pm »
Depending on usage the iPad batteries appear to last at least 3 years.
Ryan Grandusky
Re: Mackie DL1608
« Reply #5 on: January 22, 2013, 05:42:07 pm »
I've been using a DL1608 instead of my 16 channel mix wiz/outboard gear/snake for my club and bar gigs and I love it! The channel EQ control is great and I have a whole new respect now for mixing wireless. My FOH is a mic stand with an ipad holder attached. Also load out at the end of the night is so much faster.
Some negatives to consider (not enough to make me dislike my DL1608):
You have to be sparing with the compression on vocals if using wedges for the issue you already mentioned.
I don't like that the L/R main outputs shares one EQ control so you don't have independent EQ for separate left or right adjustments.
Familiarize yourself with the app and controls for quick operation. If you plan to use the tap delay as you have to swipe a few times to get there so the faster you can move the better.
Always check that you are on the right set of controls before adjusting channels. It is easy to forget you are in one of the aux sends thinking you are adjusting a particular channels volume for the main outputs.
I recommend using an ipad 2 or newer because there is a freezing issues with the app since the v1.3 release on the ipad 1. When mixing the ipad 1 will get stuck in the EQ and Processing sections and you cant get back to the mixer controls with out crashing the app.
Ryan "Squirrel" Grandusky
EV QRx 115, JTR Growler, EV ELX 115
Mackie DL1608, AH GL2400-24, Soundcraft GB4-32
Matteus Köza
  • SWEDEN - Västerĺs
Re: Mackie DL1608
« Reply #6 on: January 22, 2013, 08:42:22 pm »
what happens if the app crash by the time you restard the program? settings etc..
KORG PA2x & KORG PA3x PRO
RCF TT25a
Ryan Grandusky
Re: Mackie DL1608
« Reply #7 on: January 23, 2013, 09:31:55 am »
The App is just the control surface so if it should freeze or your ipad dies for whatever reason the Mackie DL1608 keeps going on its last settings, it doesn't care. You can forcibly close the app then open it and reconnect / re-sysnc to the DL1608 and it picks up where you left off. It takes about 30 seconds tops to reconnect. If you are operating with 2 ipads one app crashing does not effect the other.
I should add that when the app on the ipad 1 freezes you can still limp by so long as you are not stuck in an output 31 band eq screen. When the app gets struck in the channel processing screens you can still mute and control channel volume one channel at a time by swiping left or right for each channel but having to swipe 16 times to turn up the kick drum is ridiculous.
I think the issue is with the ipad 1 not having enough resources to run the Mackie Master Fader app after its most recent update. IIRC the ipad 2 has almost double the processing power of the ipad 1.
Tommy Peel
Re: Mackie DL1608
« Reply #8 on: January 23, 2013, 02:44:16 pm »
FWIW I have an iPad 1(which I bought used when it was around a year old) that is approaching 3 years old and I haven't noticed an appreciable decrease in battery life; it will still get 7-9 hours depending on usage. However I wouldn't recommend the iPad 1 because of the very limited hardware power; the iPad 2 and newer are much better.
Tommy Peel
Page created in 0.117 seconds with 23 queries.
