Author Topic: Pro1 AES  (Read 6014 times)
Árni F. Sigurðsson
Re: Pro1 AES
« Reply #10 on: January 22, 2013, 04:09:59 AM »
AES 50, 48ch to thunderbolt
http://www.rpmdynamics.com/rpm-tb48-io/
Sound technician
Menningarfélag Akureyrar / Akureyri Culture Company
Iceland
David Jameson
Re: Pro1 AES
« Reply #11 on: January 22, 2013, 09:04:09 AM »
Mark....from what I understand (which may or may not be correct!!), with the Dante audio controller for the computer, it turns the RJ45 into a basic sound card with an ASIO driver that shows up in any DAW that uses ASIO.  So connect the console to the DN9650 and the laptop to the Dante RJ45....and record up to 32x32 channels at 100Mbps or 64x64 at 1 Gbps.  From all I have seen so far, it is the least expensive way to go.  I should be able to get everything for right at $1000.
I'm sure someone will chime in with a better solution.
Thanks.
Jameson Productions
Anderson, SC 29625
jameson_prod at bellsouth.net
andy craig
Re: Pro1 AES
« Reply #12 on: January 30, 2013, 05:10:51 AM »
Recording via the Dante card in the DN9650 is restricted to 32 x 32 at 96kHz. The Madi card allows for 64 x 64 at 48kHz
Andy.
Nathan Salt
Re: Pro1 AES
« Reply #13 on: January 30, 2013, 09:00:11 AM »
Go the bridge with madi, and grab a ub-madi from digico
Nathan Salt
Re: Pro1 AES
Page created in 0.039 seconds with 23 queries.
