Hi Charlie,
Patching to 2tr outs probably won't work. My V2 block diagram should be the same as the VCM I'm assuming. It parallels the STEREO OUTs which is the mix you don't want to record and there would be no Omni to 2tr patch unless I'm wrong.
Try this- save the present scene and scroll to an open scene and save it again and title it Record or something. Go Patch > Slot Output Patch. Assign say, Omni 3 Stereo L and Omni 4 Stereo R and connect TS to RCA or whatever your recorder input jack is.
Bring up mics on the Aux only what you want to record and set the record level from it's master.
I don't quite understand your patching scheme on your second post.
Hi Taylor,
That is great news! Currently I have everything on stage going through Aux 1 (Main Speakers) and Aux 2 (Monitors).
Are you sending Aux 1 level to Main as the FOH mix and Aux 2 to stage monitors?
