Author Topic: 2x18" SUB plans....  (Read 17769 times)
John W. Boneske
    • http://www.outlaw-productions.com
2x18" SUB plans....
« on: December 23, 2010, 03:32:03 pm »
I am looking for some double 18" sub plans. The picture is like what I am looking for! Something similar to the pic would be great! Approx 48"H x 24"D x 24"W, load them with a Eminence, Peavey, or similar!
I posted before but cant find something easy enough for me to build! And, where can I find custom speaker grills?
John Boneske
Outlaw Productions LLC
502.542.1726
Re: 2x18" SUB plans....
« Reply #1 on: December 23, 2010, 03:40:16 pm »
John W. Boneske wrote on Thu, 23 December 2010 15:32
That is about as easy as it gets. 6 sides and some bracing and 3" ports.
Penn Fabrication sells grill material and ports (along with everything else you would need.
Now if you want a specific tuning, then that gets a little bit more involved-depending on what performance you are looking for.
So you would need to define what it is you are looking for-loud-low etc and what is more important.  This will affect the box size and the tuning (port size/length).
What you are basically asking for is a car with 4 wheels-an engine etc.  WHat you have not told us is how many people you want to carry-or do you want to carry a 4x8 sheet of plywood or do you want to go 150mph.
Each of those will narrow down the choices for what is best for YOU-nto somebody else.  Other people have different needs for a vehicle-just like different needs for a sub.
dB Audio & Video Inc.
Duane Massey
    • http://www.ozknozz.com
« Reply #2 on: December 23, 2010, 08:31:07 pm »
Duane Massey
Houston, Texas, USA
Winston Gamble
« Reply #3 on: December 24, 2010, 01:00:37 pm »
Duane Massey wrote on Fri, 24 December 2010 01:31
Design your own:
http://www.linearteam.dk/default.aspx?pageid=winisd
Or better yet, let Eminence do the work for you. Pick your driver here and then pick from the options.
http://eminence.com/resources/cabinets.asp
Winston
Jeff Robinson
    • http://www.geocities.com/loudspeakerguru
« Reply #4 on: January 12, 2011, 11:56:17 pm »
John W. Boneske wrote on Thu, 23 December 2010 14:32
index.php/fa/34711/0/
TL80D 48x31.5x28.875, designed for EV-DL18W or TL56D (21.375" deep) for the DL18X. If you use different woofers the tuning will not be correct.
http://web.archive.org/web/20091027060343/http://www.geociti es.com/loudspeakerguru/PROSNDFACTSno7.pdf
Dozens of designs for 12" through 18" speakers with good construction technique tips.
Jeff Robinson
Hail to thee, blithe Spirit!
Bird thou never wert
That from Heaven, or near it
Pourest thy full heart
In profuse strains of unpremeditated art
Such harmonious madness
From my lips would flow
The world should listen then, as I am listening now!
David Morison
« Reply #5 on: January 25, 2011, 07:44:00 am »
John W. Boneske wrote on Thu, 23 December 2010 20:32
These have a few more bits of wood in them but they should still be fairly easy to cut and assemble - and fewer round holes to cut and no port tubes to source.
Speakerplans G-Sub
Cheers,
David.
Tim Padrick
« Reply #6 on: January 27, 2011, 01:14:42 am »
I'd just buy some nice used QW218, SRX728, or the like.  The cost won't be much more, and when you try to sell them they will actually be worth something.
Page created in 0.077 seconds with 18 queries.
