Author Topic: NL2FC - help, how do I take apart ?  (Read 15072 times)
andrew gissing
    • http://www.stylusra.com.au
« on: March 10, 2010, 01:51:25 am »
Hi all,
I feel really stupid in asking this but i've got an NL2FC that looks like the attached pic.. and I do not know how to dis-assemble it.
index.php/fa/28627/0/
It's a cable i've been asked to repair; i've never used this series of speakon - mine are all newer or older (and NL4 or NL8)
The trouble i'm having is getting the terminals exposed. I'm guessing that I need to do something with the grey sliding jacket but I could be wrong. I know you slide and pull when you unmate from a socket but do you still slide to get at the internals ?
These appear to be like the female jack line connectors - those are a bit counter-intuitive but once you know what you're doing you're fine.
help !
Andrew
Evan Kirkendall
Re: NL2FC - help, how do I take apart ?
« Reply #1 on: March 10, 2010, 01:54:32 am »
There's a little slot on the grey shell that you stick a small screw driver into and it allows you to pop the shell forward and access the terminals.
Evan
« Reply #2 on: March 10, 2010, 02:08:09 am »
 http://www.neutrik.com/Secure30/getMedia?encoding=ISO-8859-1  &client=neutrik&saveAs=true&saveAsName=Speakon_S  ystem.pdf&mediaPath=D:%5CDATA%5CCLIENT%5Cneutrik%5Cmedia  %5Cdownloads%5C&mediaSavedName=Media_293225003.pdf&c ontentType=application/pdf
Not terribly clear, but it's a start.
Have fun, good luck.
Tim Mc
andrew gissing
« Reply #3 on: March 10, 2010, 02:13:12 am »
This is the one near where it says "open push >" ?
Do you try and push that down, then get the grey thing to slide over.. while the screwdriver is still in the hole and then remove screwdriver ?
I've been trying that maneouvre for a while and figured I was going about it wrong.
Do I persist ?
Andrew
PS: Next time you're in Perth Australia look me up. If I was more switched on about ATL being part of soundwave I would have made contact with you before.
Chris Gruber
« Reply #4 on: March 10, 2010, 02:38:16 am »
Try the easy way! Step 1: Cut off NL2  Step 2: Install NL4  Problem solved. $4 will eliminate a big headache.
-Chris
Arthur Audio
"It never ceases to amaze me how many sound guys think the measure of their work is solely defined by whether or not their subs are capable of sonically vaporizing squirrels from 20 meters."
Jason Dermer
« Reply #5 on: March 10, 2010, 08:39:33 am »
+1
Jason Dermer
jason@asburyaudio.com
cell: 732-616-3463
office: 732-938-3100
"Rock & Roll and cars are just slightly different versions of the same mental disorder."- Peter Egan
Tim Weaver
    • http://www.weaverimaging.com
« Reply #6 on: March 10, 2010, 01:46:24 pm »
Dynamite and an icepick.
Phil LaDue
« Reply #7 on: March 10, 2010, 07:12:12 pm »
The biggest sledge you can find, or wire cutters.
andrew gissing
« Reply #8 on: March 10, 2010, 07:39:26 pm »
Ok I get it !
I'm glad it's not just me that's having trouble.
The assembly instructions are quite clear and easy to follow - but I guess they designed this plug ONLY to be assembled and never dis-assembled !
Thanks guys,
andrew
Joe Brugnoni
« Reply #9 on: March 11, 2010, 10:35:00 am »
NL -2 SUCK!!!!!
Cut them off and run them over with anything very heavy!
Be nice to everyone as you can learn something from anybody
Page created in 0.033 seconds with 21 queries.
