Tom Young wrote on Sun, 13 April 2008 16:01 |
The problem with HotSpots is twofold:
1) the irratic frequency/phase response makes them less than the norm as far as feedback stability.
2) the irratic frequency/phase response makes their perceived response at the users ear change drastically with normal head movement.
I think the worst experience I have had with these is with a singing pianist with a boom mounted mic. When they move their head the response changes. When they move the mic the feedback characteristics change. This driver configuration is not employed anywhere else (other than as part of a 2-way system). It would be less of an issue if more drivers were used in either both axis (ala Bose 802) or in just that one axis (aka: column loudspeaker). With just the 2 drivers the phase interaction is more pronounced whereas with more drivers the net/overall response is more dense and is smeared in a (comparatively) beneficial manner.
If that makes sense.
OK, I get that you don't like "Hotspots". I am not pimping hotspots but just maybe there is some method to their madness. Keep in mind these are very application specific vocal monitors
But first I need to puncture the common (over simplified) understanding of feedback... namely making a monitor speaker or microphone flat will give you the most GBF. If feedback was simply determined by, and closely followed, the frequency response of microphones and speakers, you would never be able to EQ feedback out with a handful of narrow band notch filters or even 1/3 oct EQ. SInce most speaker bumps are broad, you would use up all of your notches just trying to kill the first peak.
Instead I offer a slightly more nuanced mechanism for feedback. When the microphone picks up sound from a speaker, it amplifies that and it almost instantaneously shows up again at the speaker. The next repeat takes the time to travel the path length between speaker and mic, and so on. This path length (wavelength), determines the lowest node and spacing between feedback nodes. Changing path polarity just swaps the peaks with notches in this comb filter variant (much more narrow). Now that we have established this series of nodes where feedback "can" occur, system frequency response determines which nodes will take off first, second, etc. If the path gain is less than unity, each repeat is at a lower level and will just tail away (like cheap reverb), if gain is more than unity it tries to make a mostly sinewave at that pitch. In a well rung out system when pushed to the edge of feedback you can multiple notes. Since these feedback nodes (combs) are very narrow, the corrective EQ can likewise be narrow, unless the mic (or speaker) is not fixed, in which case the varying path length smears the nodes around.
Getting back to the Hotspots, with their lumpy off-axis response, if those response dips are coordinated with the feedback nodes, presto we can get an improvement in GBF. Also the relatively short path length from keeping mic close, prevents lower frequency (longer path) nodes from even developing.
This suggests to me a very specific geometry for mic and hotspot location to benefit from this mechanism.
Nobody is saying hotspots are remotely hifi especially off axis, and I wouldn't generally try to use them with wireless mics (no mic stand to put them on)
If these monitors are more than several inches from the microphone (my guess in the OP's case), I see little benefit and lots of issues.
